Ansys Learning Forum Forums Discuss Simulation Fluids Correct CFX Pre Setup to avoid isolated fluid regions Reply To: Correct CFX Pre Setup to avoid isolated fluid regions
Mark Owens
Hi, you do not create inlets or outlets on internal faces. Inlets/outlets are boundary conditions. They can only exist on faces that have no volume mesh on the exterior side. The internal faces are just either connected mesh regions or walls.
