Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Correct CFX Pre Setup to avoid isolated fluid regions › Reply To: Correct CFX Pre Setup to avoid isolated fluid regions
November 4, 2024 at 4:03 pm
Hi Mark,
Thank you for that response. I am trying to place walls only on those faces I want to block off and create an inlet and outlet for the geometry which has an internal fluid volume, however I am having an issue where on the inlet and outlet faces, two faces are created and I do not know how to set the conditions for the secondary face created (.298 versus .333)
