ErKo
Hi
  1. You need to select a mesh node or vertex and create a pressure or spl result there.
  2. Far-field radiation surface is only valid for frequency domain analysis (used there for far field results say in harmonic acoustics), so does not exist in coupled field transient (it is greyed out as it is not valid for this type of analysis).
    All the best
    Erik
