Ansys Learning Forum Forums Discuss Simulation Preprocessing CONVERTING STL FILE IN TO SOLID Reply To: CONVERTING STL FILE IN TO SOLID
peteroznewman
I was able to open the .stl file in SpaceClaim and you also provided a .scdoc file of the same data.
Using the tools on the Facets tab, I am able to use the Auto Fix button and the Separate All button to divide the STL data into multiple bodies, then I deleted all but the main body.  using Check Facets, there are two problems.
The question I have is if the Rhino 7 surface had these defects.
I have Rhino 7 and can open .3dm files.  Can you provide the .3dm file also please?
