Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Solving multiple design points is extremely slow › Reply To: Solving multiple design points is extremely slow
November 1, 2024 at 5:40 pm
Federico
How are you initializing each solution for each design points when Updating Selected Design Points? How does that compare with your initialization when you do it manually?
Update of Design Points can initialize a solution as defined in the solver or use an existing solution from a previous design point. If your changes in the geometry are too important, perhaps the latter can take longer to converge
