November 1, 2024 at 12:34 am3343534645 SubscriberDear Ansys Team, I sincerely hope that you can publish the theoretical basis for calculating the geometric stiffness matrix for solid elements. Compared to existing literature or textbooks, the method you use in ANSYS APDL for calculating the geometric stiffness matrix seems unique and difficult to trace. It would be a great pity if all the theories on geometric stiffness matrices for solid elements published over the past few decades turned out to be incorrect! Thank you for your response. Best regards,
November 4, 2024 at 3:06 pmPedram Samadian Ansys EmployeeHi, Thanks for contacting us. You may find usefull information in this regard in ANSYS Mechanical APDL Theory Reference at Theory Reference . I hope it helps. Thanks, Pedram
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
                        1487
                        1358
                        1189
     You are navigating away from the AIS Discovery experience
