TAGGED: apdl, mechanical, mechanical-apdl, nodes, pretension, shell-elements
October 31, 2024 at 8:49 am
FARDELE
SubscriberHi, I have two components, one solid type and one shell type. The shell type I want to make a pretension and to lengthen it I want that the extreme nodes are linked with the nodes that it had in relation in the instant 0 with the solid, so that later when it wants to return to its initial position it moves everything making like a compression. Then I want to apply a vertical force over the solid and see how this Sheel type will react.
I have tried to create one step (LSWRITE,1) with the pretension and another step (LSWRITE,2) with the applied force. But from there I don't know how to join those nodes.
How could I do it?
PD: I am using Ansys Mechanical APDL -
October 31, 2024 at 9:29 am
ErKo
Ansys EmployeeHi
See the inistate command - there are examples that apply pre-stress on shells in the apdl help manual.
Hope this helps.
All the best
Erik
5719
1305
