Ansys Learning Forum Forums Discuss Simulation Fluids CHT Simulation Using VOF Model (Steady-State) Reply To: CHT Simulation Using VOF Model (Steady-State)
In Fluent a heat flux bc forces that amount of heat through the surface uniformly. If the heat transfer is limited on the fluid side temperature is increased until sufficient energy is passed over: that can result in a fairly high dT in some cases.
As I can't see any results it's difficult to comment.
