Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Ansys Discovery – Replicating a Mechanical Engineering Textbook Example › Reply To: Ansys Discovery – Replicating a Mechanical Engineering Textbook Example
Hi Erik,Â
Thanks for the very quick response.Â
I cranked up the fidelity to the highest resolution (0.34mm)
It did not make a difference to the value of the resultant. I even experimented by applying a Torque equivalent to the applied load still no difference.Â
I understand and appreciate that everything falls within a margin of error (Simulation or real case). For example, in the real world, the load would not be applied centrally or distributed evenly etc.Â
 By removing the anchor/ground fixed support and applying a Fixed Hinge support at the point of rotation, the solution improved to 198N. Very good indeed.Â
The resultant at point O is at 213N.Â
The other question I have for you is?
Is there a way to find the vector or direction of this value? From my earlier post, there is a 20.55 deg vector on this resultant reaction force.
