3D Design
3D Design
Wrong dimension display in Sketch mode in SpaceClaim
    • Dato
      There is something wrong with dimension display in Sketch mode in a .scdoc file but it is normal before designing in this .scdoc file.
      The large space should be a dot but it doesn't display.  However, the dimension display becomes normal if I new a design.
      I have tried to reboot SC but it doesn't work. I have tried changing something in Detail tab but it still cannot recover.
      Any suggestion would be a great help.
      Regards.
    • Charudatta Bandgar
      This could be possible due to the regional language you have set in Windows. Can you check once? The decimal operator could also be the reason.
      Regards
      • Dato
        I check it and shut down the computer for several hours and it works.
        Thanks
