November 23, 2019 at 9:58 pm
Veronica
SubscriberHi everyone,
I would to know how to apply compression only support in this plate. I think that I should apply compression only in the hole, the force in one of the two directions and in the other I should apply a fixed support or displacement with x=0, y=free and z=free (in 3D case). But I'm not sure about all this. Can you help me please.
November 24, 2019 at 12:49 am
peteroznewman
SubscriberIs this a 3D model? Is so, pick the cylindrical face of the hole and apply a compression only support. Don't apply the force F on the right, that will be taken care of by the compression only support. Do apply the force on the left. It might turn out that the solver can obtain a solution by using weak springs to prevent a "pivot error" that can occur on an insufficiently constrained model.Â
You could make this model fully constrained by making it a 2D plane stress model and slicing it in half horizontally.
November 24, 2019 at 2:46 pm
November 24, 2019 at 3:20 pm
peteroznewman
SubscriberYou can ignore the warning. You got a good result.Â
You should add a Mesh Sizing control to the two circular edges, and make the elements half the size of the default size or set the number of divisions to 36.
Note that 1 N on a half model means 2 N on the full model.
If your question has been answered, please mark that post with Is Solution to show that this discussion is Solved, or ask a followup question.
November 24, 2019 at 4:11 pm
Veronica
SubscriberThank you so much!
November 26, 2019 at 10:14 pm
Veronica
SubscriberWhat will be the difference if I apply bearing load at the hole and displacement x=0 en the left edge. Because I have done this and I have different results
November 27, 2019 at 9:34 pm
- The topic ‘compression only’ is closed to new replies.
4858
1587
1386
1242
