October 21, 2024 at 8:28 pm
hsuan.huang
SubscriberHi All, I am currently working on a simulation involving a flexible corrugated rubber sleeve bending around a 4-inch pipe. I could use some advice on the following:
- Best Approach: What would be the optimal method to simulate this scenario considering the complexity introduced by the corrugation?
- Mesh Considerations: Given the corrugated surfaces, I anticipate needing a large number of mesh nodes and elements. Any recommendations on managing or optimizing this?
- Material Behavior: The sleeve will undergo significant deflection. How can I best model the large deformations of the rubber?
Thank you in advance for your insights and guidance!
October 22, 2024 at 9:10 am
Harshvardhan
Ansys EmployeeHi,
Ansys has a white paper published that might be related to your querry. It is about the finite element analysis of braided corrugated hoses, outlining the methodology for creating and analyzing three-dimensional finite element hose models.
wp-braided-corrugated-hose.pdf
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines) -
October 22, 2024 at 3:23 pm
hsuan.huang
SubscriberHi Harshvardhan,Thank you for sending the link to the white paper! It serves as an excellent design reference. 🙏I'm currently looking for advice on the optimal setup in Ansys Mechanical to simulate the large deflection behavior of a flexible, highly featured rubber-like material as it wraps around a pipe or any other structure with significant curvature.Any insights or guidance you could provide would be greatly appreciated!Best regards,Sam
Ansys Innovation Space
1388
1188
1100
1015
