Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Absorption Coefficient Definition › Reply To: Absorption Coefficient Definition
October 21, 2024 at 9:27 am
You'd set the band absorption in the Materials panel. The database is best used once you set up manually to re-use the material elsewhere, but user-defined databases do have a few issues so make sure all models are ON before reading the database for your materials.
