October 21, 2024 at 7:53 am
krishnasai807
SubscriberAs the title suggests I want to stop my simualtion when the report definition I created reaches a threshold value. I had tried to use convergence conditions but stop criterion in convergence conditions is residual value rather than absolute threshold value. Could anyone help me.
Thank You.
Krishna
October 21, 2024 at 10:40 am
Forum ModeratorYou can try using a trigger to monitor a value via a UDF and trigger a journal to save case & data when that value is reached. Another option is to use Scheme commands, but I don't particularly recommend that.Â
I can't give more information on the above as this is a public forum. My usual approach is to monitor the value of interest and manually stop the model once it's reached. That also means if the threshold is met by an anomaly that can be seen because it's run longer than planned.Â
