The selected/available restart point(s) are invalid.
    • 1617836513
      I set up the settings for restart in the static structure as in figure 1, after that I want to continue the calculation after clicking on the STOP button (without making any changes to the model in the meantime), and I chose a sub-step before the last step of the convergence calculation. But it appears that the restart point is invalid, why is this?
    • Harshvardhan
      There can be multiple reasons for the solver to remove/modify restart points.
      You can check out the following links about restart points in Ansys and see if they have something that can help you out:
      18.5. Using Solution Restarts
      16.1.4. Restart Analysis
      I hope this helps.
      Harshvardhan
