Ansys Learning Forum Forums Discuss Simulation Electronics Optislang MotorCAD HPC integration Reply To: Optislang MotorCAD HPC integration
nkb221
I've sorted the issue with multiple instances not starting. However, I do still have the issue that both single and multiple instances run extremely slow compared to the test run in MotorCAD as outlined in the tutorial. The test run takes ~10 mins however the Optislang run with a single MotorCAD instance takes over an hour. Can you please advise?
