October 16, 2024 at 8:33 pm
bailin.zhang
SubscriberHello,
I want to have a lens system which can form the image from infinity to a limited distance as sketched below. Due to the conave system will reduce the field of view. Can you have some suggestions or initial starting configuration for such a compace lens system which can realize the function and reserve the input field of view? Thank you.Â
October 18, 2024 at 3:01 pm
November 9, 2024 at 3:37 pm
bailin.zhang
SubscriberHi Akhil,
Thank you for your sample mdoeling.
While, it seems your input is only from an central infinity field. My case question is as shown in my drawing, it from different field (angle space). I also need to keep the original input Field of view. Do you have some ideas about this? Best, Bailin
1890
1414
1304
