Ansys Learning Forum Forums Discuss Simulation 3D Design How to Draft 3D Line, Sweep, Loft? Reply To: How to Draft 3D Line, Sweep, Loft?
Tim Dukes
If you have curves you can double click the curves and select the 'Cylinder' tool and then just type a radius this would be a quicker way to create the above.
