November 16, 2019 at 12:42 pm
Vishnuraja
SubscriberHi guys I am presently working on fluent for solving multiphase flow over cylinder.
For the problem I need to plot vertical force Vs time .I could actually see the vertical force from reports.but wat I need is to plot the vertical force Vs time...It will be greatful if anyone help me out of this.
Thank you -
November 16, 2019 at 3:10 pm
Vishnuraja
SubscriberThis is so important..if anyone could help me..pls. -
November 21, 2019 at 9:47 am
Forum ModeratorYou need a monitor, and then plot that as the model runs.Â
As an aside, bumping a post on the day it's added isn't going to speed anything up. After a few days it's fair enough as we may have missed it.Â
November 22, 2019 at 11:30 am
Vishnuraja
SubscriberThanks for the rply
Actually what I need is force Vs flow time .I didnt get it what you meant by monitoring .could we actaully monitor force Vs flow time..or is it lift coeff..
I don't need to plot lift coeff..if monitoring force is possible could you pls elaborate.. -
November 23, 2019 at 7:40 am
Amine Ben Hadj Ali
Ansys EmployeeYou go to report definition and create a force monitor. Check some tutorials which explain it. -
December 2, 2019 at 1:10 am
Vishnuraja
SubscriberThanks for the reply.
Actually I was using ansys 16.1 and there is no such report definition option in it.
I tried monitors , but there is no force monitor in it . I was able to monitor lift coefficient but for my problem velocity keeps changing so I need to plot force itself. -
December 2, 2019 at 5:53 am
Amine Ben Hadj Ali
Ansys EmployeeThen the old force monitor plot. Try updating to an actual release -
December 2, 2019 at 8:38 am
Vishnuraja
SubscriberHi..
I dnt understand what u meant. It will be helpful if elaborate.
Actually there is no force monitor in monitor..Lift coeff and drag coeff are available .but I need to plot vertical force -
December 2, 2019 at 10:36 am
Amine Ben Hadj Ali
Ansys EmployeeCheck https://confluence.cornell.edu/display/SIMULATION/Flow+over+an+Airfoil+-+Numerical+Results
December 3, 2019 at 2:57 am
Vishnuraja
SubscriberHello I checked the link..So we could actually get the values of force from reports as mentioned in the link. But the problem we have to pause the iteration each time and go to the report for getting the value..So if we need let's say force for 100 time periods,we have to stop iteration 100 times and go check the report values and plot the graph manually...Does there exist anyother method or any software in which we will be able to plot force Vs time.. -
December 3, 2019 at 3:34 pm
Forum ModeratorNo, read up on transient monitors and plot the result to a graph. That (if you do it correctly) will output time on the x-axis and force on the y.Â
December 3, 2019 at 4:31 pm
Amine Ben Hadj Ali
Ansys EmployeeFluent can do that as you read the out file back into it. -
December 4, 2019 at 1:28 am
Vishnuraja
SubscriberHi guys I dnt understand. All I can find in fluent is force coeff in monitors..Could you guys please suggest any threads or links regarding the way to plot force Vs time as you have mentioned in the previous replies. -
December 4, 2019 at 11:21 am
Amine Ben Hadj Ali
Ansys EmployeeHey search after force in the help related to your working version. And look into https://confluence.cornell.edu/display/SIMULATION/Flow+over+an+Airfoil+-+Numerical+Results
Viewing 13 reply threads
- The topic ‘Plotting force Vs time on fluent’ is closed to new replies.
Ansys Innovation Space
1036
1004
859
798
