November 16, 2019 at 6:13 am
AmarisDLR
SubscriberHello,
I am trying to model a shelf bracket as a 2D surface.
When I try to get the factor of safety, I only see Max and Min of 15. It will not change , even as I modify my geometry and loads.
I am using Structural Steel as the material, and I see the S-N curve in engineering data.
What could be the issue?
November 17, 2019 at 11:29 am
peteroznewman
SubscriberThe only thing I can think of is the load is very light. In the example below, if I reduce the load by a factor of 10^-6, I can get that effect. What if you increase the load by a factor of 10^+6? I can look at your model if you use File, Archive to create a .wbpz file, which you can attach after you post your reply and say what version of ANSYS you are using.
- The topic ‘Factor of Safety’ is closed to new replies.
1831
1387
1248
