Ansys Learning Forum Forums Discuss Simulation General Mechanical Hyperelastic Materical Reply To: Hyperelastic Materical
mohan.urs
Hey,
Instead of checking total deformation try checking for total strain in particular directions, that should give you meaningfull results.
The total deformation here is giving max on the outer ends because those elements in the edge of structure have no proper reaction whereas the tip has full reaction from the base (which is why the deformation is 0, so it is actually behaving properly). So deformation is not the proper tool to judge the physical behaviour here.
Let me know if you need more help.
Thanks.
