Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Error: An error occurred when post processor attempted to load a specific result › Reply To: Error: An error occurred when post processor attempted to load a specific result
Update 1
Update on the progress since my previous post:
I finally got a working LS-DYNA release up and running. This is what I use now (I also reinstalled the student release (R14) which is the only one I could get working yet):
I also tried to solve the input file via LS-Run and got similar results: the student version 14 does work and the 2 other R15 releases don’t (Status “Terminated”).
Is this the same documentation I should get via the link? I can view some documentation via the download page of LS-DYNA you send me.
Is the number of nodes limited in the normal release you send? I expect our application to be exceed the standard student limits. I might try to get the normal R14 running for that.
Kind regards,
Bram
