Ansys Learning Forum Forums Installation and Licensing Ansys Free Student Software Error: An error occurred when post processor attempted to load a specific result Reply To: Error: An error occurred when post processor attempted to load a specific result
Reno Genest
Hello Bram,
The end time cannot be 2e-2s if they have results at time 0.219s.
Are you able to run a simple cube model on its own (no Static Structural) with Explicit Dynamics? If not, there may be a problem with your installation.
If you can run a simple cube, then maybe there is a problem with the tutorial model.
Note that Ansys employees are not allowed to upload and download models from the Ansys Forum.
If you are a commercial customer, please create a support case on the Ansys Customer Support Space (ACSS) and we will have a look at the model:
customer.ansys.com
I recommend that you try with LS-DYNA.
Another option for this tutorial would be to use Transient Structural. Load the beam statically in step 1 (Time Integration=off) and in step 2 remove the load and let the beam vibrate dynamically (time integration=on):
Reno.
