Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Mass-spring system does not move properly when the spring is non-linear › Reply To: Mass-spring system does not move properly when the spring is non-linear
October 10, 2024 at 2:42 pm
This is a Full (not Mode-Sup) transient, correct? I tried it and it works for me. I verified it by scoping a deformation result to the named selection I had to create to scope the spring to the mass. An indirect way to check if it is moving is to create a probe for the nonlinear spring.
