Ansys Learning Forum Forums Discuss Simulation Fluids Different results when using overset dof and sliding mesh. Reply To: Different results when using overset dof and sliding mesh.
Federico
Hello Alberto,
Are both cases modeling the same thing? It seems like you are computing forces generated by the flow on the blade for the overset case, while for the sliding mesh you are introducing rotation through a source to the corresponding zone.
