Ansys Learning Forum Forums Discuss Simulation Fluids VOF Open chanel flow directly floating solar pv Reply To: VOF Open chanel flow directly floating solar pv
Velocity is fine, https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v242/en/flu_ug/flu_ug_sec_mphase_using_steps_vof.html%23sec-mp-vof-open_channel_velocity_inlet
Have you given the "thin" wall a material that's not Aluminium and did you add a thickness?
