Ansys Learning Forum Forums Discuss Simulation Fluids FLUENT UDF dynamic mesh+ MIXTURE Reply To: FLUENT UDF dynamic mesh+ MIXTURE
That's a profile, not a UDF. You may want to check the quantity of the omega numbers (ie how many are set).
The animation could be a setting error in the panel, but more likely it's recording the wrong window. Check how you've defined everything, but welcome to the wider club: we've got far too many movies of residuals after similar mishaps.
