October 8, 2024 at 11:49 pm
kklng
SubscriberÂ
I'm having issues with my ACP model. This is a sandwich composite material. Ideally, this frame should be uniform thickness, however, because of the inner tapers, there is extra thickness. I read that extrusion guides may be able to fix this problem, but I am not sure how to define that extrusion guide. Also, is there a way to add relief cuts? Any help is appreciated, thanks!
October 18, 2024 at 10:26 am
ashish.khemka
Forum ModeratorHello,
I am not an expert but please see if the following link helps you: 5.3. Solution (ansys.com)
Ashish Khemka
