ANSYS ACP Modelling Issue
    • kklng
      I'm having issues with my ACP model. This is a sandwich composite material. Ideally, this frame should be uniform thickness, however, because of the inner tapers, there is extra thickness. I read that extrusion guides may be able to fix this problem, but I am not sure how to define that extrusion guide. Also, is there a way to add relief cuts? Any help is appreciated, thanks!
    • Ashish Khemka
      This post seems duplicate of following post: ANSYS ACP Modelling Issue
      I will close this one.
      Ashish Khemka
  • The topic ‘ANSYS ACP Modelling Issue’ is closed to new replies.
