TAGGED: -Force-calculation, data, moment-calculation, unsteady-flow
October 6, 2024 at 5:13 pm
sobol.ofiszal
SubscriberHi,
I've encountered a problem regarding a access to a mean force and moment data sampled via the Data Sampling for Time Statistics feature. Is it possible to access this data either via a file or directly in fluent in the same way as instantaneous values of force and moment can be access via report tab or a .out file? The only way to access that I've found was via a cummulative plot tab, but I wonder where could I access this data in a way similar to one mentioned earlier.Â
Best regards
October 7, 2024 at 12:00 pm
Forum ModeratorDon't think so. If you monitor the value(s) you can work out the average outside of Fluent.Â
October 8, 2024 at 9:20 am
sobol.ofiszal
SubscriberThank you very much. Just wondered if Fluent is collecting this data already, I could access it somehow.
