Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Pressure and Thrust Distribution in Fluent CFD POST for a propeller › Reply To: Pressure and Thrust Distribution in Fluent CFD POST for a propeller
October 4, 2024 at 10:02 am
Thank you!Â
2) for the thrust distribution along the propeller blade in radial direction, I need to find the thrust force at different sections of the blade. However the force acting on the plane at different position along the blades in Y-axis direction (propeller axis direction) does not seem to be accurate.Â
So how to find the thrust force at different sections of the blade ?Â
