Ansys Learning Forum Forums Installation and Licensing Ansys Products Errors with multi-connected bodies using AQWA Reply To: Errors with multi-connected bodies using AQWA
Hilal Çelik
Thanks for your help. The gaps between the pontoons are 40 mm, yes they are too small. How can I set the faces as non-diffraction surfaces?
