Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Huge amount of memory in hard disc needed › Reply To: Huge amount of memory in hard disc needed
October 3, 2024 at 1:48 pm
Hello
 A few ideas:
Try the Iterative (PCG) solver as it may not require as much RAM.
Considering using Linear elements where appropriate. (Add an Element Type control to specific bodies)
In the Solver Output Controls, you can turn off unneeded quantities written to the result files. You may want to test on a smaller model to confim you are not disabling anything you need.
