Ansys Learning Forum Forums Discuss Simulation General Mechanical the simulation results do not match the defined material curves Reply To: the simulation results do not match the defined material curves
Armin
Could you describe more about your model? Is the first plot associated with a uniaxial tensile simulation versus experiment? I can see that one of the simulation curves (red) is overshooting the experiment (black) while the other red curve is in good agreement.
