Ansys Learning Forum Forums Discuss Simulation General Mechanical Thermal analysis using shell elements and midsurfaces Reply To: Thermal analysis using shell elements and midsurfaces
deepesh.p.gurdasani
Case 1: Using midsurfaces
Boundary condition
Mesh : Automatic settings
Result: It can be seen that there is hardly any difference in temperature even though all three materials are different
Case 2: Using solid bodies
Boundary conditions
Mesh: Automatic settings
Result: Here it can be seen that there is significant difference in temperature as per material properties.
Shouldn't midsurface case and solid case give same results? Please guide.
Thanks
