Ansys Learning Forum Forums Discuss Simulation General Mechanical elastic membrane and acoustics Reply To: elastic membrane and acoustics
tabajabassel12
Hey again,
thanks again,i have an issue that the chamber filled by water closed by the membranes how we can insure that the water is treated as incompressible flow, bc since i saw the deformation is the same from both surfaces and it should be less to the water surface since the warter is incompressible .
so how can i be sure that the water is treated as incompressible?
sorry to bother you man and thanks a lot
