Electronics
Electronics
Odb ++ import issue
    • harunprakash.mech
      While importing odb++ file ,only copper layers and dielectric layers are getting imported,solder mask layer is missing. Can you suggest ways to import solder mask layer to pcb.
    • Chunhui Zhang
      What tool are you using? Classic Icepak or AEDT Icepak? Thanks.
    • Aymen Mzoughi
      Try using either Ansys EDB or IPC2581 for import
    • Chunhui Zhang
      If you are using Classic Icepak, the solder layer will be ignored. Please manually create the solder layer using a block object. In AEDT Icepak, solder layer can be imported into PCB component.
