Ansys Learning Forum Forums Discuss Simulation General Mechanical Explicit Dynamics – Body not moving Reply To: Explicit Dynamics – Body not moving
gustavo.antoniolli
As you suggested, I changed the End time and adjusted the geometry so there is no gap between them. I kept everything else the same as it worked with 4400 mm/s, but I still haven't gotten any results.
I applied an initial speed of 3000 mm/s to test, and I'm still unsuccessful.
The conditions I used were: fixed support at the base and a displacement on the moving parts to restrict movement only in the direction of the velocity. Note that there is no variation in kinetic energy, indicating that no movement is occurring.
Here are some images of the model:
