September 26, 2024 at 9:24 am
qjaxod13
SubscriberHello,
I would like to post-process the transient state calculation result data obtained from FLUENT.
Instead of doing this within FLUENT, I want to proceed in ANSYS CFD-Post.
In FLUENT, I saved the data file through the following steps: File → Export → Solution Data → File Type (CDAT for CFD-Post & Ensight).
After importing the above data file into CFD-Post, only the last time step appears.
I want to know how to import all the time steps. Thank you.
September 26, 2024 at 12:48 pm
Federico
Ansys EmployeeHello,Â
when you export or write solution data in Fluent, each file stores the data for a single time step. If you want to have data over several time steps, you will need to write multiple .dat/.cdat files.
You can set Autosave from the Solution tab to write your data at specified intervals over the course of your Fluent simulation.
