Ansys 产品
Ansys 产品
How to split solid bodies?
    • hao1996
      When I use an imported mesh from Hypermesh in Ansys Mechnical, the imported geometries are set as one solidbody like the following picture:
      When I need to set one of these bodies to rigid body, the error of "All bodies under this part must have the same setting for stiffness behavior" occurs. So, how can I split these bodies into seperate ones?
    • Ashish Khemka
      All bodies in a body group (of a multibody part) must have the same Stiffness Behavior. When Stiffness Behavior is Rigid, the body group acts as one rigid mass regardless of whether or not the underlying bodies are topologically connected (via shared topology).
      In addition please refer to the following links:
      Error: All bodies under this part must have the same setting for stiffness behavior. How to fix? (ansys.com)
      6.1.4.2. Rigid Bodies (ansys.com)
      Ashish Khemka
  • 您必须登录才能回复此主题。
