Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › make mechanical analysis on topology result › Reply To: make mechanical analysis on topology result
September 25, 2024 at 6:05 am
You can use the shrinkwrap option to smoothen out features and then use smooth option.
For an example for Topology Optimization you kindly go through the following link:
Topology Optimization of a Bell Crank| Ansys Innovation Courses
The example in the link covers the steps required to use the optimized geometry for further analysis.
Regards.
Harshvardhan
