Ansys Learning Forum Forums Discuss Simulation Photonics Running Lumerical FDTD files on a Campus cluster using Sun Grid Engine (SGE) Reply To: Running Lumerical FDTD files on a Campus cluster using Sun Grid Engine (SGE)
Lito
If you are able to run Lumerical simulations on your local desktop (university computer), check the Lumerical license configuration on the local machine, from which server and port it is obtaining the licenses from. And use the same license configuration on the cluster. See the following KB for details:
Otherwise, consult with your IT/admins that the cluster/nodes are allowed to connect/communicate on the ports used by the Ansys license manager on your license server.
