Ansys Learning Forum Forums Discuss Simulation Electronics RMxprt parameter change causes a problem that requires the software to be closed Reply To: RMxprt parameter change causes a problem that requires the software to be closed
Metropolia motorsport
It seems the error log can't be copy pasted for some reason, so basically it says that the exception code is 0xc0000005 and the description is "exception access violation". Module name ansysedt.exe
