October 21, 2019 at 12:08 am
zoiralli
SubscriberHello everyone,
I am trying to work solid65 command for unreinforced UHPC. I have followed the suggestions in this discussion /forum/forums/topic/entering-non-linearity-in-workbench-for-concrete/?postbadges=true, but my results are not right. The commands which give more accurate results are the following:
*SET,ELEM_TYPE_ID,1
ET,ELEM_TYPE_ID,solid65
KEYOPT,ELEM_TYPE_ID,1,0
KEYOPT,ELEM_TYPE_ID,3,2
KEYOPT,ELEM_TYPE_ID,5,0
KEYOPT,ELEM_TYPE_ID,6,0
KEYOPT,ELEM_TYPE_ID,7,1
KEYOPT,ELEM_TYPE_ID,8,0
and for concrete model:
ET,MATID,SOLID65
R,MATID,0,0,0,0,0,0
RMORE,0,0,0,0,0
MP,EX,MATID,48000
MP,PRXY,MATID,0.18
MPTEMP,MATID,0
TB,CONCR,MATID,1,9
TBTEMP,22
TBDATA,1,0.2,0.8,15,120
TB,MISO,MATID,1,3,0
TBTEMP,22
TBPT,,0.0035,120
TBPT,,0.0025,108
TBPT,,0.0015,72
My main problem is how to input the stress relaxation factor (c9) as the TBDATA command allows only 6 constants. In the manual it is stated that: "If constants 1-4 are input and constants 5-8 are omitted, the latter constants default as discussed", meaning C9 should be 0.6 which is the default value. However, when I edit the model in APDL C9 is set to zero. What should I do to include in the command the C9=0.6? Thank you in advance.
Zoi
October 25, 2019 at 6:29 pm
TARTON
SubscriberHeres the syntax for the TBDATA command
TBDATA,Starting location in table,Maximum of 6 inputs separarted by commas
If you want to enter constants 1-4 and 9 and omit 5-8, you can do so in 2 lines or 5 lines of command
2 lines:
TBDATA,9,0.6
5 lines:
TBDATA,1,0.2
TBDATA,2,0.8
TBDATA,3,15
TBDATA,4,120
TBDATA,9,0.6
October 25, 2019 at 8:37 pm
zoiralli
SubscriberHi TARTON,
Thank you! Another question I have; how to input the tensile stress-strain experimental data for concrete? The command above is for compression and want input tension too. Is that possible?
Thank you
May 23, 2020 at 12:46 pm
Semih
SubscriberHi,
I don't think you can input tensile stress-strain data for Solid65 element. It is linear up to the tensile strength. If you want to include damage-plasticity after the tensile strength is reached, then I think you should use Microplane elements.
Regards,Â
- The topic ‘Problem with Stress Relaxation after cracking-solid65’ is closed to new replies.
5874
1306
