I beam to CFT column , concrete´s behavior – solid65
    • fkezada5
      hi guys! nice to meet you, my name is felipe quezada, from Chile.
      i really need your help. i made some models of  " I BEAM - CFT (concrete filled tube) column connections" in ansys worbench V 15.0.
      my problem is related to how to model the behavior of concrete inside de column. i have read about the element solid65, which is one of the most appropiate element for this case. i have copied some codes in the command option, but when i try to run the program, it doesn't work.
      i tried to model a simple concrete cube with the code of solid65, but nothing happens.
    • fkezada5
      i tried to input the following code
       CONCRETE COMMANDS:
      ET,MATID,SOLID65
      R,MATID,0,0,0,0,0,0
      RMORE,0,0,0,0,0
      MP,EX,MATID,29250
      MP,PRXY,MATID,0.2
      MPTEMP,MATID,0
       TB,CONCR,MATID,1,9
      TBTEMP,22
      TBDATA,
       1,0.3,0.8,1.5,25
      TB,MISO,MATID,1,35,0
      TBTEMP,22
      TBPT,,0.0001,2.925
      TBPT,,0.0002,5.7
      TBPT,,0.0003,8.325
      TBPT,,0.0004,10.8
      TBPT,,0.0005,13.125
      TBPT,,0.0006,15.3
      TBPT,,0.0007,17.325
      TBPT,,0.0008,19.2
      TBPT,,0.0009,20.925
      TBPT,,0.001,22.5
      TBPT,,0.0011,23.925
      TBPT,,0.0012,25.2
      TBPT,,0.0013,26.325
      TBPT,,0.0014,27.3
      TBPT,,0.0015,28.125
      TBPT,,0.0016,28.8
      TBPT,,0.0017,29.325
      TBPT,,0.0018,29.7
      TBPT,,0.0019,29.925
      TBPT,,0.002,30
      TBPT,,0.0021,30
      TBPT,,0.0022,30
      TBPT,,0.0023,30
      TBPT,,0.0024,30
      TBPT,,0.0025,30
      TBPT,,0.0026,30
      TBPT,,0.0027,30
      TBPT,,0.0028,30
      TBPT,,0.0029,30
      TBPT,,0.003,30
      TBPT,,0.0031,30
      TBPT,,0.0032,30
      TBPT,,0.0033,30
      TBPT,,0.0034,30
       TBPT,,0.0035,30
        please, i really need some helps, these models are to my degree.
       thanks! and i´m sorry for my english, it is not the best ha ha ha
    • fkezada5
      I beam  - CFT column connection
    • ramon mata
      could you solve your problem? what solution did you take? any recommendation is welcome
  • The topic ‘I beam to CFT column , concrete´s behavior – solid65’ is closed to new replies.
