Ansys Free Student Software
Ansys Fluent
    • TeebaQata1
      I am following a youtube tutorial for a 3D airfoil. On ansys fluent, the tutorial says to set the boundary conditions for the intlet (Velocity inlet), where the tutorial says to set the velocity magnitude as 12m/s then press okay. the inlet dialog box of the online tutorial is in the first image below. however, the dialog box that I get has more options and different options under the turbulance option as seen in the second image. when I insert the velocity that the tutorials says (12 m/s) and press okay, I get the error message in the third image. Could you please help me out with what would be the issue or what to do?
      Thanks.
      Which turbulence model are you using?
    • TeebaQata1
      I am using K-omega SS. I have manged to solve the problem. However, the error might have been in the additional equation used to solve turbulent flow (K-omega), I might have set a wrong value in the outer limit of the domain, which thus, would have caused the error.
  • The topic ‘Ansys Fluent’ is closed to new replies.
