Ansys Learning Forum Forums Discuss Simulation Photonics Simulation error in port source Reply To: Simulation error in port source
Guilin Sun
Unfortunately we are not allowed to test script in this forum. Before running the FDTD, please check if the FDTD file is correct and proper. Once it is ok, you can use another python file to run it, in order to isolate the cause. Please try simple structure first.
