Ansys Learning Forum Forums Discuss Simulation Electronics 180 Degree Phase Shift When Measuring S21 Reply To: 180 Degree Phase Shift When Measuring S21
David Prestaux
did you calibrate the ports by specifying integration lines at the port? this may be the cause.
