September 19, 2024 at 1:23 pm
373352238
SubscriberIn the first step, I applied an axial load to my column. Then, in the second step, I imported a vehicle model. However, at the beginning of the simulation, the shell elements on the exterior surface of the vehicle were deleted, starting with the points and then the shell elements.I checked the vehicle model but couldn't find the issue. Could anyone help me understand where the problem might be? Thank you in advance for your responses!
September 23, 2024 at 6:35 pm
Matthew Middleton
Ansys EmployeeDoes that mean you used External Model system to import? What application is this? LS-Dyna pre? Ansys Mechanical? Whag format is the file you imported? Were there errors or warnings? There will normall be messages when something in the impirt is skipped. Check the message panel in Mechanical and workbench.
September 24, 2024 at 2:16 am
373352238
SubscriberI used LS-PrePost for modeling and successfully imported the vehicle model into the component model without any errors during the import process.
6540
1311
