Ansys Learning Forum Forums Discuss Simulation 3D Design Space claim scripting FileSetting problem Reply To: Space claim scripting FileSetting problem
Atharv Joshi
I think you have used Smart Variable selection to record the script for importing the files.
Smart variables such as 'FileSettings1' is not pre-defined in a new session so you can face errors.
You can switch to index selection based approach to record the initial code and later modify as required.
Regards
Atharv
